Download: http://archive.info-mac.org/text/quicknote-12.hqx
File name......: QuickNote 1.2
Date of release: 10/24/97
Have you ever needed to jot down a note quickly and be able to easily
find it later? Ever wanted to copy a selection of text while web
browsing for later reading without copying and pasting between
applications or saving the text to a file? QuickNote can do these things
and more at the touch of a key (which will instantly bring up a text
editor) without having to leave the application you are in!
Of course, you'll be able to hit another key at any time that will bring
up a list of all your notes, which you can edit, delete, search, replace,
print and move from category to category (create as many categories as
you like) with ease! QuickNote lets you do all standard text editing
including changing fonts, styles, sizes, color, etc. Another extremely
handy feature allows you to select text from any note and have QuickNote
automatically paste the text directly into any text document you are
working on.
New features added in version 1.1:
Color Menu, support for Internet config & ICeTEe, smart quotes, fixed
Kaleidoscope bug with scroll bar, replace all, can now drag over menu
titles, several bug fixes and added many new PlugIns!
New features added in version 1.11:
Added ability to set printing margins, added new plugins (Add CRs & Email
Reply), several Bug fixes (fixed conflict with TypeIt4Me, fixed problem
where some characters were dropped while typing in certain applications,
fixed alias problem).
New features added in version 1.2:
Added templates, added popup menu for template insertion into any
editable text, added text form ability (option-tab from field to field
within text if fields are within [] brackets), PlugIns now use folder
hierarchy (for different PlugIn categories), added several new plugins,
several Bug fixes (find next, zeros in dates bugs fixed).
System Requirements.
Min. System..: 7 on up
Min. Hardware: Mac SE or better (Works great on PowerMacs!)
Shareware....: $20
Author.......: John V. Holder
email address: [email protected]
Home Page....: http://www.northcoast.com/~jvholder
