PICTInText
PICTInText
Download: http://archive.info-mac.org/text/pict-in-text.hqx
Written by DeForest Shotwell
13010 87th Ave. NE
Kirkland, WA
PICTInText is an utility that you can use to embed PICT files in your
SimpleText documents. PICTInText will use any PICT file to create,
number and install the necessary PICT resource into your text file
without the need for a graphics application (Photoshop,
GraphicConvertor, etc.) or the need to use ResEdit. Works wonderfully
with screen captures. It does it simply and effectively in 5 simple
steps.
