Personal Log v2.1.3 68K
Download: http://archive.info-mac.org/text/person ... 13-68k.hqx
Personal Log is the premier note processor for the Macintosh, allowing
you keep multiple, text-based notes in one simple file. Personal Log is
perfect for work logs, diaries, research notes, and light record
keeping. Personal Log also utilizes PowerTalk¹s Digital Signature
technology to allow you to electronically notarize each note to ensure
it¹s authenticity (making it also perfect for patent notes, engineer
logs, and patient logs). Personal Log is based on the advanced WASTE
Text Engine, which allows you to edit text greater than 32K in size and
insert embedded objects, such as pictures and sounds. Furthermore,
Personal Log make full use of Apple¹s latest MacOS technologies, such
as the Drag Manager and the Speech Manager, and supports InternetConfig
by Peter N. Lewis (command-click the two URLs above).
