NuEdit1.3.2E.sit
NuEdit1.3.2E.sit
Download: http://archive.info-mac.org/text/nuedit-132e.hqx
NuEdit1.3.2 English version.
Copyright(c)1997-98, by Noriaki Misawa.
NuEdit is styled text editor. Interestingly, NuEdit has a color palette.
Accordingly, you can color a text very easily.
System Requirements
MacOS version 7.0.1 or later
What's New...
1.3.2(98.4.14)
Fixed 'Enter Find String'.
Fixed Using Dictionary. If the Selected-text is large, It crashed NuEdit
before 1.3.1. Changed to max-size 255 characters.
Fixed Auto-save. If NuEdit is background, freezed. Change to view an
alert by Notification Manager.
Available new File-open, save... dialog - 'Navigation Services'.
Fixed preview-open dialog. If you press option-key, no-preview open
dialog.
Available Save to SimpleText-Japanese version format.
Change to clear button with press option-key.
Fixed file save preferences.
Future 1.3
Available Export HTML format with style.
Added Color Menus in Contextual Menus.
Add Preferences when Open File.
Add Shortcut-key with MercutioMDEF.
Available ContextualMenus.
Copyright
WASTE text engine is copyright (c)1993-1998 by Marco Piovanelli.
Registration
NuEdit is Shareware ($10). Please use kagi software or read a
manual.
Japanese version
Check out NuEdit's home site at:
Support
E-mail:
