My Secret 1.0 Carbon - encryption program for Macintosh
Download: http://archive.info-mac.org/text/my-secret-10-cbn.hqx
My Secret 1.0 is a tool to encrypt and decrypt text messages. It
supports strong 448 bit Blowfish encryption as well as support for
custom external encryption schemes. Beside other plugins, it comes
with a free Rijndael plugin. For secure hashing, it uses a
combination of SHA1 and MD5. My Secret supports drag & drop, uses
built-in compression and can securely wipe out files. It has an
easy-to-use user interface while offering a fair amount of security.
Encrypted data is in 7-bit plaintext ASCII format and suitable to be
sent in emails without further modification.
My Secret is $10 shareware and can be tried out without any limitations.
Requirements: PPC Macintosh, 2 MB RAM, OS 8.0 or higher (OS X for
Carbon version)
Author: Erich H. Rast
Email: [email protected]
Web: http://home.snafu.de/erich/shareware/mysecret.html
Order: http://order.kagi.com/?UCV
