Easy View 2.62
Easy View 2.62
Download: http://archive.info-mac.org/text/easy-view-262.hqx
Easy View 2.62 - Easy View is a program for browsing collections of
structured (but otherwise plain) text files, large or small. It allows
very fast access by recognizing the internal structure. All of the
following text formats can be viewed using Easy View - setext, including
TidBITS and similar publications, Info-Mac, c.s.m.p, or similar digests,
Mail collections - Internet, Navigator, Notebook, etc., Dictionaries and
Plain text. New - An extension menu is added for using external code
(Compatible with BBEdit). Font and Size menus are made hierarchical.
Fixed - Cancel key does not crash after "Do you want to save?" dialog.
