DOCMaker Document Patcher for 8.5
Post by Info-Mac » November 7th, 1998, 11:00 am
Download: http://archive.info-mac.org/text/docmaker-doc-patch.hqx
The DOCMaker Document Patch for Mac OS 8.5 will quickly update existing
DOCMaker documents for use under Mac OS 8.5. After patching, the
documents will still work under older Mac OS versions. The patcher
replaces the horizontal navagation scrollbar in those documents that have
more than one chapter. This scrollbar needs updating for use under Mac
OS 8.5. The symptoms that are fixed by this patch are long pauses in the
Macintosh after using the popup menu in the navagation scrollbar. This
patch is only needed for DOCMaker documents whose version number is 4.8.3
or earlier.
