DOCMaker v4.8.4
DOCMaker v4.8.4
Download: http://archive.info-mac.org/text/docmaker-484.hqx
Release of DOCMaker version 4.8.4 - Mac OS 8.5 compatible.
DOCMaker gives you the Macintosh user powerful tools for creating
self-contained and self executing multi-media documents containing
graphics, information, and links to other software and information. By
incorporating QuickTime Video, sound, AppleEvents, "Hot Picture Buttons"
and more, documents that you create can become an exciting multi-media
experience for your readers. No other software is needed by the reader
to open, print, and fully experience your documents. The "viewer engine"
is embedded into the documents to make distribution and use a simple and
easy process. Depending on the optional capabilities you save with your
documents, the actual size of the documents can be very small.
Fee schedule for educational, non-commercial, and commercial use. Order
form attached.
