DEVONnote 1.0b
DEVONnote 1.0b
Download: http://archive.info-mac.org/text/devon-note-10b.hqx
Short description:
Easy-to-use, intelligent note pad, bookmark manager and webcam browser
Long description:
DEVONnote is a note pad capable of intelligently storing and organising
plain or rich texts and file aliases. Store your bookmarks in DEVONnote
too, browse the Web using the integrated browser based on Apples's
WebKit, capture interesting notes immediately, organise webcams or
create cross and Wiki-style links.
Key features:
- Stores plain and rich texts, text clippings, iChat log files and
bookmarks
- Supports dynamic Wiki-style links and static cross links
- Easy-to-use interface
- Integrated browser based on Apple's WebKit (ÈSafari EngineÇ)
- Helps you to sort in new stuff (ÈClassifyÇ, ÈSee AlsoÇ)
- Advanced text editing including rulers, highlighting and realtime
word count
- Lightning-fast, intelligent search function
- Supports services (like CalcService, WordService or BlueService)
- Provides multiple services and a Dock menu
- Supports drag 'n drop in both directions
What's unique:
- Im- and exports Finder comments
- Imports MS Word documents using Panther or AntiWordService
- Stores aliases to local files
- Captures contents from the built-in browser and organises webcams
- Groups or ungroups contents, organises them in hierarchies
- Batch im- and exports data extremely fast
- Works flawlessly with huge databases (>100 MB)
- Does not need indexing but searches the data faster than the
competition
- Uses all major features of the operating system
History:
NEW Discounts for students available
NEW Default toolbar item to choose the browser view
Improved Search popup menu and field of browser toolbar combined
Improved Faster verification before flushing contents back to disk (up
to two times faster)
Improved Faster toolbar search
Improved "Destroy" command renamed to "Delete All Instances"
Improved Shortcut of "Launch" command changed to Command-O
Improved Stability of kernel and user interface
Fixed Import of plain text clipping files (.textClipping extension or
'clpt' HFS type) didn't recognize unicode text. In addition, the
default plain text encoding (see preferences) is used for all other
plain text clippings.
Fixed Preview of linked plain text documents sometimes used the rich
instead of the plain text font
Fixed Number of words displayed in the info panel was sometimes not
identical to the one displayed in windows
Fixed Changing the "Check spelling as you type" preference wasn't
applied to already opened browser windows
Fixed After toggling between note pad/outliner views, "See
Also"/"Classify" did not work if there was a document selected
Fixed Sorting by kind was not always updated after modifying the
path/URL of an item
Fixed The relevance of search results was sometimes not correct if
"Phrase"/"Wildcards" and "Content" options were active
Fixed Ungrouped groups were not removed from search/classify results
Fixed Rebuilding was not possible if the verification found some
errors. Now it's possible to continue or cancel.
Fixed It was possible to add a useless "Classify" command to the toolbar
Fixed "Append To Rich Note" service did not work
Fixed Crash after dragging unsupported files to icon view
Fixed Crash after deleting the last search result
License:
Commercial/Trial (US $20, Special introductory price US $15 until
2004/04/30)
Author:
DEVONtechnologies
System Requirements:
Mac OS X 10.2.x and Safari 1.x or Mac OS X 10.3.x
Shop:
https://www.devon-technologies.com/shop.php
Product Page:
http://www.devon-technologies.com/produ ... onnote.php
http://www.devon-technologies.com/files ... note_1.jpg
Download: 2.4 MB, 2469 KB, 2528536 bytes
http://www.devon-technologies.com/download.php
http://www.devon-technologies.com/files ... ote.dmg.gz
