Clp Convert 1.0
Clp Convert 1.0
Post by Info-Mac » February 17th, 1997, 11:00 am
Download: http://archive.info-mac.org/text/clp-convert-10.hqx
Clp Convert 1.0
By Mike Tilstra
& TaDPoL Tech
This application converts both picture and text clipping files to text files and
picture files. The reason for making this is so you can edit and modify the
contents of clipping files. You then use this app again to convert them back
into clipping files.
To use Clp Convert, you can drag files over its icon, run it and use the open
command, or script it with applescript. Easy huh? :)
Clp Convert is free, but it is not in the public domain.
Eventhough Clp Convert is free, I'm going to remind you to register other
shareware you may use.
Parts of Clp Convert are ©1997 Mike Tilstra
Other Parts Based on DropShell 2.0
