Clipping Converter - directly convert ordinary text and image clipping to SimpleText readable format. You can also convert Netscape, Internet Explorer and MacOS 8.5 Bookmarks without pain! You can edit text before converting them and you can merge multiples files by drag&dropping them on the application! Simple and fast.
