Add-Strip 3.4
Add-Strip 3.4
Download: http://archive.info-mac.org/text/add-strip-34.hqx
Add-Strip 3.4 - TEXT documents created on a PC or a mainframe are
invariably formatted inappropriately for use on a Macintosh. They
often contain
unnecessary control characters, carriage returns, the wrong kind of
quotation and apostrophe marks, and so forth. Manually reformatting
these documents can be a tedious and time-consuming task. Add/Strip
(A/S) has been designed to automatically perform much of the work of
cleaning up TEXT files destined for import to page layout, word
processing, database, or spreadsheet programs, as well as export from
these programs to a PC or mainframe computer. All in a fraction of
the time needed to manually reformat using a word processor. It can
also batch-search-and-replace a folder of textfiles with up to 250
replacements, begin-of-file & end-of-file inclusions.
