Download: http://archive.info-mac.org/app/ez-note-20.hqx
Announcing a major upgrade of the Mac-only utility EZNote!!
File name......: EZNote v2.0
Date of release: 7/10/2001
Have you ever needed to quickly jot down a note and easily find it later?
While Web browsing, have you ever wanted to copy text selections for
later reading, without copying and pasting between applications or saving
the text to a file? EZNote accomplishes these tasks, and more, at the
touch of a key or a click of a mouse--without having to leave the
application you are in!
Pressing another key brings EZNote to the front with a listing of all
your notes, which you can edit, delete, search, replace, group in
categories, print, or move from category to category, (create as many
categories as you like), with ease!
Another extremely handy feature allows you to select text from any note
and have EZNote automatically paste the text directly into any document
in any running application. And of course EZNote supports all the
standard text editing goodies, including changing fonts, styles, sizes,
etc.
EZNote comes with many PlugIns which allow you to modify selected text in
any application. Strip Line Feeds from your email, get rid of all email
reply >> > characters with one PlugIn keystroke or mouseclick. Also, you
can create your own PlugIns sets!
Previous users will appreciate that EZNote is now an application, no
longer a Control Panel. As our users have requested, you can now have
multiple windows open, each note can be greater than 32k, pictures can be
mixed with text, and it fully supports drag & drop. And there's lots
more new features!
System Requirements.
Min. System..: 7 on up through OS9!
Min. Hardware: Mac SE or better (has 68k and PowerPC native code)
Shareware....: $20
Author.......: John V. Holder, Software
email address: [email protected]
Home Page....: http://www.northcoast.com/~jvholder
