MI Convert 2.7 PPC English
Download: http://archive.info-mac.org/sci/calc/mi ... 27-ppc.hqx
MI Convert is a metric imperial calculator and converter for measurements of
distance, length, square, weight, capacity, velocity, temperature,
circumference. This is the only conversion program I know of that will give
your imperial conversions in written format for distance, length,
circumference to one sixteenth of an inch and to one dram in the weight
conversions.
Runs as full 30 day tryout, after this time registering the program will
enable it again.
-Changes
Added fluid measurements and dry US gallons to the capacity window.
Added nautical measurements to the distance and length window.
The program now auto converts as the values are entered.
-This program single user licence is $19 US.
-Requirements:
Power Mac running OS7.6.1 or above.
This version will not run on OSX.
-Compressed BinHex size:
-1020k
-This program can be used on CD distribution.
-Web: econsoftware.com/econ.html
-Enquires and questions should be directed to: mailto:[email protected]
