Download: http://archive.info-mac.org/sci/calc/ha ... tor-12.hqx
Haxial Calculator is a high precision mathematical assistant that
evaluates normal (infix) expressions to practically any accuracy. Results
can be viewed in normal, fraction or scientific forms and the option of
working in a different radix no longer restricts you to the decimal
system. Worksheets enable you to solve larger problems in a more suited
environment as well as allowing you to save your work. In addition Haxial
Calculator incorporates unit and radix conversion utilities for your
convenience as well as complete support for variables.
Other calculator programs blindly attempt to copy physical hand-held
calculators by displaying buttons on the computer screen, and an
appearance and function that closely mimics a hand-held calculator. At
Haxial, we believe this approach is fundamentally flawed. A computer is a
far more powerful device than a hand-held calculator, and thus it is
illogical and limiting to duplicate hand-held calculators on a computer.
Haxial Calculator allows you to freely type expressions in a form natural
to humans and much more suited when using a computer keyboard. For
example, you can type a formula such as this into Haxial Calculator:
34 + e^(56 - 24.6487) * 1.24
When you press enter/return Haxial Calculator will interpret the
expression, check for syntax errors, evaluate the result and display it
to screen using the display mode and accuracy of your choice. Freely
typing expressions is far superior to other methods such as clicking
buttons.
More information at:
http://www.haxialsoftware.com/products/calculator/
