Googolator 1.3
Googolator 1.3
Download: http://archive.info-mac.org/sci/calc/googolator-13.hqx
Googolator is a small, fast, arbitrary-precision calculator for
those times when you can't be bothered starting up Mathematica. :)
It lets you do exact calculations with arbitrarily large numbers
(limited only by memory). It can also input/output numbers in any
base from 2 to 36. At the moment only integer arithmetic is supported.
Googolator 1.3 is a Carbonized app that runs natively on OS X.
It also runs on OS 8.6/9.x if CarbonLib 1.3 or later is installed.
The shareware fee is $20. For more details see:
http://www.trevorrow.com/googolator
Andrew Trevorrow ([email protected])
