Econ Calculator 1.1.1 - Eng 68k
Download: http://archive.info-mac.org/sci/calc/ec ... 8k-111.hqx
Econ Calculator 1.1.1 English 68k
23/08/2001
-The program
This is a simple to use calculator which has settings to make both single
auto calculations or multiple calculations, this is an ideal replacement to
the calculator provided with your OS, still keeping things simple but also
with the addition of a few more options such as a more appealing user
interface, being able to save your calculations as a text file and having
the facility to print, multiple calculations are written into a simulated
paper roll at the bottom of the calculator and can be saved as a text file
or printed out from the "Print" menu. Calculations possible include
addition, subtraction, division, multiplication and square root. Online user
guide at: http://econsoftware.com/econcalculator_111UG.html
-Changes
(NEW) Enter key can now be used to calculate sum.
(CHANGE) "Rubber" button removed.
(CHANGE) The "C" button now becomes the "C/CE" key, this replaces the
function of the green "Rubber" button which has been removed.
(CHANGE) Keyboard layout.
-Requirements:
Power Mac running OS7.5 or above, not OSX compatible.
-Compressed Bin Hex size:
-544k
-Web: http://econsoftware.com/econ.html
-Enquires and questions should be directed to: mailto:[email protected]
