YP Vecteurs 1.0 (mathematics-physics, french version)
Download: http://archive.info-mac.org/sci/yp-vecteurs-10.hqx
YP Vecteurs is the french version of YP Vectors.
YP Vectors is a teaching tool for physics/mathematics lessons. It is used
to learn about vectors and components. YP Vectors displays a vector in two
dimensions, and its two components. The user can change the magnitude and
the direction of the vector using the mouse. A window shows the numerical
value of the magnitude, the direction, the x component and the y component
of the vector. The user can change the scale used to draw the vector.
