Download: http://archive.info-mac.org/sci/toto-turbo-20.hqx
TotoTurbo is a Carbon application that runs natively on MacOS 8.1
with Carbon or newer. TotoTurbo enormously facilitates your
formulation of complex systems of Totocalcio, Totip, Enalotto,
LotoFoot and Israelian Toto. TotoTurbo 2.0 lets you:
- create systems from only 1 column to 13 triples (15 triples for
Israelian Toto)
- constrain the columns to have minimum and maximum signs, maximum
consecutivity, minimum and maximum simmetries, minimum and maximum
interruptions, minimum and maximum parallels, even and odd groups,
sequences, constrained columns, derived formulas
- constrain systems with even more detailed criteria
- constrain columns by pickets
- recover unlimited number of wrong conditions
- reduce the constrained system in order to get second and third category wins
- print the columns on paper and directly to forms
- import, export and manage the set of Totocalcio contests
- export the system to plain text
- customize the application to suit user's needs
- check the system to see if you have won
What's new:
- carbonized code
- abandon of 680x0 code
- native support of MacOS X through CarbonLib
- Navigation Services support
- newer Internet Config support available since MacOS 8.5
- faster kernel
- better compatibility with PowerToto 1.5/2.0
- automatic insertion in the applications lists of the Help Center
- some bugs fixed
