pro Fit 5.1.2 Trial
pro Fit 5.1.2 Trial
Download: http://archive.info-mac.org/sci/pro-fit-51-trial.hqx
pro Fit 5.1.2 Trial is an evaluation copy of pro Fit 5.1 for
the Mac OS.
It is a freeware pro Fit 5.1.2 version which is very well suited
for carrying out smaller tasks. It is used by people who do not
need the full power of the commercial version, and therefore do
not want to pay for it.
Compared to the commercial version, pro Fit 5.1.2 Trial is a
"light" version which has the same feature set, but imposes a
few restrictions (e.g. a limit on the size of data). It can be
used without limitations and can be re-distributed for free.
This is a fat version that runs on PowerPC and on 68k machines
equipped with a floating point unit. For a version that runs
on 68k _without_ FPU, visit http://www.quansoft.com, where
you can also find more information about pro Fit and view the
user manual.
pro Fit is a powerful tool for linear and nonlinear curve
fitting and the analysis, processing, plotting, and evaluation
of numerical data and mathematical functions. It features:
- a spreadsheet editor for handling data sets of millions of
rows and columns
- a drawing editor for creating high quality graphs and
presentations of data and functions,
- powerful linear and nonlinear curve fitting and data anlysis
tools,
- a built-in Pascal compiler and extended Apple Script support
for programming functions and macros,
- Full support of complex numbers and variables in the built-in
compiler.
- scriptability and recordability for automatically recording
and replaying your actions,
- a context sensitive help mechanism and Apple Guide help,
- support for the new appearance and contextual menus
of Mac OS 8.x,
- support of Mac OS 8.5.x.
QuantumSoft
http://www.quansoft.com/
