Point Recorder 1.2.0 ppc
Post by Info-Mac » November 21st, 1997, 11:00 am
Download: http://archive.info-mac.org/sci/point-r ... 12-ppc.hqx
Point Recorder is an application which allows to record automatically the
successive point screen coordinate covered moving the mouse.
Point Recorder can work also in background.
In that way is possible to set properly Point Recorder and to switch to
other application such as a Quick Time player or an image viewer and
tracking with the mouse a contour or a moving point in the foreground
application.
Point Recorder will record in background the successive mouse coordinate
using the method requested by the user.
Method of tracking mouse coordinate can be customized using different settings.
Uses for Point Recorder range from industry analysis of contours to
scientific data collections in biology experiments.
Result can be saved as text file on disk.
Infinite uses are possible, maybe in completly different field.
New in the 1.2 version:
Recording pressing the mouse button (also with Point Recorder in background).
Shareware, available both for Mac and native for PPC.
This is the PPC version.
Inclusion in CD ROM is permitted.
Further info at
