Download: http://archive.info-mac.org/sci/moonmenu-203-jp.hqx
This is the Japanese version of the MoonMenu package.
MoonMenu renders a small picture of the moon in its current phase on
your computer's screen in your menubar next to the clock. MoonMenu also
comes with an application that will calculate lunar data for any given
date! The MoonMenu application is a small but powerful panel that allows you
to investigate all of the information about the moon for any date and
time between the years 1923 and 2039. It also controls the settings for
the tint of the moon so you can optimize it for your monitor. There're
even built in definitions for the items listed above... just one click
away.
MoonMenu draws the current phase of the moon in the menubar. The menu,
when selected, reveals the following information:
* A textual description of the moon phase
* Illumination percentage
* The moon's age in days
* Current lunation number
* Farmers' Almanac names for the current lunation
* Upcoming quarter predictions
* Automatic "blue moon" detection that actually colors the moon blue
* Sun rise/set times
* Twilight rise/set times
* Moon rise/set times
Version 2 is now fully compatible with Mac OS X!
New to 2.0.3
9 and X:
* Fixed problem with text in some windows.
* Fixed registration problem.
X only:
* Fixed font metrics for MacOS X 10.2 in some dialogs and windows.
* Fixed problem with "Launch Application..." menu item under some 10.2 systems.
* Fixed problem with Moon dissappearing from the menubar during
registration reminder.
