Download: http://archive.info-mac.org/sci/convert ... its-22.hqx
The file "ConverTable Units 2.2.sit.hqx" is attached. It should replace the
file "ConverTableUnits211.sit.hqx" in the "_Science_&_Math"
directory. This is the abstract for the file:
This is a demo version of Synergy Creations' ConverTable Units software
for Macintosh. Version 2.2 release date: January 2003.
ConverTable Units is a unit converter with several unique features.
ConverTable Units teaches how to do unit conversions.=A0 Click the "show
tutor" triangle, and ConverTable Units shows you the math required for the
conversion you've asked it to perform.=A0 In fact, ConverTable Units "thinks"
about conversions using a "unit cancellation" method widely taught in high
school and college science courses.=A0 By showing how conversions are done,
(not just spitting out an answer!) ConverTable Units represents a great
teaching and learning tool.
Other features:
- Plug-in architecture (add your own units)
- Easy to use calculators included-both algebraic and RPN!
- Over 300 units available!=A0 112 built-in units (unregistered), 91 more whe=
n
you register, plus (at last count) 107 more available through plug-ins.
- To unlock all the features, there is a $15 registration fee.
http://www.synergycreations.com/converTableUnits.html
System Requirements:
- PowerPC Mac, Mac OS 8.1 or later
