Mac CallerID 1.2.2 Update Notice
Inter-computer communication software: Modem dialers, file transfer, telecommunications, etc.
Download: http://archive.info-mac.org/comm/mac-caller-id-122.hqx
Announcing the official release of 1.2.2
What's new:
• Tested on Mac OS 8.5 prior versions should work as well.
• Fixes a bug with AppleScript and now returns the correct first or last
call. The returned calls were previously backwards.
• Mac CallerID will now quit when you press the power key and select restart
or shutdown.
• The "Next" and "Previous" buttons on the single call display now work
properly. The order was backwards ever since the order of incoming calls was
switched from the bottom of the list to the top.
• Mac CallerID Dialog's height is now greater allowing you to view more items
in the "Display All Calls" list.
• Mac CallerID Dialog can now be shrunk by clicking the "Collapse Box" or by
Double clicking the title bar if you have check "Double-click title bar to
collapse windows is checked in the Appearance control panel (Mac OS 8.5) and
Window Shade.
• Substitute Caller List is now sorted by number to speed up Substitution of
caller name. This is done after you close the Substitute Caller Dialog.
• Substitute Caller name can now contain 28 characters.
