Download: http://archive.info-mac.org/comm/berkel ... tor-10.hqx
Berkeley Packet Monitor
Version 1.0
Berkeley Packet Monitor is a Mac OS X network traffic monitoring and
diagnostic utility.
Berkeley Packet Monitor uses the Berkeley Packet Filter devices built
into the Mac OS X operating system to log and re-assemble all packets
entering and exiting from a specific network interface.
Berkeley Packet Filter can be configured to log ICMP, TCP, and UDP
packets and will allow you to view the raw data contained in each packet
sent or received.
Berkeley Packet Monitor was compiled on Mac OS X version 10.3 using
Objective-C Cocoa.
If you like the program or use it frequently you may register your copy
at http://www.kagi.com/.
The current version of this program is 1.0 and may always be downloaded
at:
http://homepage.mac.com/niteowl69/
Revision History:
2004.08.01 Version 1.0
- Initial releease.
©2004 NiteOwl Software
