Elegance-1.2.4c
Elegance-1.2.4c
Download: http://archive.info-mac.org/nwt/util/el ... c-demo.hqx
Elegance provides a series of shortcuts and several features
designed to enhance the Newton and make it easier and more
pleasant to use.
Elegance installs a small, movable toolbar on the Newton's screen.
This toolbar provides instant access to a set of basic features that
deal with the look of text. The toolbar also allows the user to
custom build additional menus that bypass the time consuming steps
required to use many of the Newton's own tools.
This version will work in Demo mode for about a month or if you
already own Elegance you can use your existing key to register it.
The enclosed user manual is in Adobe Acrobat format.
Lightbulb Factory, Inc.
69 Wooster Street
New York, NY 10012
http://www.lightbulb.com
