Newton HI Toolkit
Newton HI Toolkit
Download: http://archive.info-mac.org/nwt/dev/hi-toolkit-10.hqx
Newton HI Toolkit
Enclosed is my Newton Human Interface Toolkit. It is a set of templates for
designing Newton interfaces. It probably belongs in newton/dev.
The contents have been virus-checked with Disinfectant 3.2. The enclosed file
is a Compact Pro self-extracting archive that has been BinHexed. The following
text is in the readme file:
by Trygve Isaacson
v1.0
10/28/93
Nothing fancy--this is just a couple of MacPaint documents containing a bunch
of the Newton human interface elements in what I believe to be accurate
dimensions. There is no real trick to creating this stuff, but it is pretty
tedious, so I hope this will make it easier for you to sketch out your Newton
ideas.
If you have any corrections, suggestions, or additions you would like to see,
please send them to me at:
This package may be freely distributed, but please make sure to include the
Read Me file with it.
