Newton Program T-Cube submission
Download: http://archive.info-mac.org/nwt/app/t-cube-10.hqx
--========================_25202124==_
T-Cube v1.0
August 12, 1994
Designed by: Dan Venolia ([email protected]) & Forrest Neiberg
Newton Port: Les Vogel
T-Cube is a new way of entering characters and text on Newton. It
complements handwriting recognition and the soft keyboard. Characters
correspond to "flick" gestures made into the T-Cube window.
After you have installed T-Cube, it is accessed by tapping its button in
the Note Pad status bar. T-Cube shows nine buttons arranged like a wheel.
Pressing and holding the pen down in any of the button shows a different
"pie menu" containing eight characters. You can "type" a character by
moving the pen in one of the eight directions, then lifting it.
This sounds like a tedious way to type, but as you start to memorize common
characters, such as space and "e", you can make the gesture directly,
without invoking the pie menu. Using the menu, an "e" is made by pressing
in the "north" button and dragging to the north-east. As a gesture, this
is a simple flick that starts in the north button and proceeds to the
north-east. You should have the most common characters memorized after
only an hour of use.
More information on the design of T-Cube can be found in:
Venolia, D. and Neiberg, F. "T-Cube: A Fast, Self-Disclosing Pen-Based
Alphabet," in Proceedings of CHI '94 (Boston, April 24-28, 1994), ACM
Press, pp. 265-270.
The Newton T-Cube package may be distributed freely, provided that this
text accompanies it. T-Cube may not be distributed for profit without
prior written consent.
(c) 1994 Apple Computer, Inc. All Rights Reserved.
Content-Type: application/mac-binhex40; name="T-Cube.hqx"
Content-Disposition: attachment; filename="T-Cube.hqx"
