Sticky Newts 2.07
Sticky Newts 2.07
Download: http://archive.info-mac.org/nwt/app/sti ... ts-207.hqx
Sticky Newts 2.07 - is a fun new application for your Newton designed to
make it easy to jot down reminders, to-do lists, directions, draw maps
or just doodle. Styled after the familiar form of a paper sticky note,
Sticky Newts allows you to place multiple notes on your Newton screen,
view them all simultaneously, or hide them all with a single tap. In
addition, Sticky Newts allows you to quickly jot down notes no matter
what other applications you are running on your Newton. Sticky Newts
floats above all your other applications, providing constant access to
your information. All the while, remaining as unobtrusive as possible.
System Requirements - Newton MP120/130/2000 or eMate 300, Newton
OS2.0/2.1 or later. Application requires 288k.
