Download: http://archive.info-mac.org/nwt/protore-size-box.hqx
ResizeBox ET 1.0
by E. Jeremy Tira-Thompson
663 Mount Hope Rd
South Fork, PA 15956
[email protected]
http://www.pitt.edu/~cft1/Jeremy/Jeremy.html
This is a NewtonScript proto that allows programmers an easy way to create
views that can be intuitively resized by the user. I have included a
sample package which uses several resize boxes in different ways. In this
way, you can easily see how the protoResizeBox feels & reacts with
different settings, and the different design issues to be considered.
(clipping problems in particular - a good scrolling setup would usually be
an ideal solution)
The demo program is a simple little thing that allows you to add polygons
to a main view & then move them around. The views include a
protoResizeBox, and some have multiple protoResizeBoxes. This shows how
the different justifications of the protoResizeBox change its behavior.
[... clip ...]
Requirements:
Any 2.0 Newton system should be capable of running the demo package, and
protoResizeBox may be capable of running on older systems with some
modification. I want to move on to other projects.
Disclaimer:
It's not my fault if anything goes wrong! Tell me about it though, I will
try to keep it from happening again.
I hereby release this proto as freeware. As long as I get due credit for
the proto, I will be happy. Please inform me of inclusion on any CDs or
other mass distribution.
