Download: http://archive.info-mac.org/nwt/ecdict.hqx
ECDict is a English-Chinese dictionary module for CLex.
You will be needing:
A Newton with NOS2.0 or later.
At least a set of Chinese font in unicode format.
CLex dictionary engine. CLex is a shareware multilingual dictionary engine.
Notably it supports Chinese/Japanese and other script systems. There is a
built-in memo so that you can put a new word in the memo for your later
peruse. You can also look up a word online by selecting the word or simply
place the caret under the word you want to look up. A TapBar button is also
included so that you can have access to CLex almost everywhere at any time.
You can get the engine on my homepage or from Info-Mac.
Enjoy!
Joseph Chen
