Download: http://archive.info-mac.org/inet/web/nt ... per-as.hqx
A handy utillity that allows quick saving of web address' (or email, or
news) to either netscapes bookmark file, a separate bookmark file, or
(best of all) your own little web page. This applescript writes all the
tags to a text file that Netscape can read with "clickable" links on it.
It also has a hot key and a memory. If you hold down the "command" key
while running the program, it will save the site to the last place you
saved one. This is shareware and requires applescript, system 7.5, and
"Jon's Commands" applescript additions (which are available at just
about any archive for free). This program was written by myself.
Gabriel Weatherhead
[email protected]
G. Weatherhead
3401 Hillview M.S. R6-003
PaloAlto, CA 94304
