Download: http://archive.info-mac.org/inet/web/nt ... -in-10.hqx
QuickTime MIDI Plugin 1.0
Copyright (c) 1996 by Terry Greeniaus
QuickTime MIDI Plugin is a plugin for Netscape Navigator 2.0 or greater
which lets you play MIDI files off the Internet right in the Netscape
window! Just click on the link to the MIDI file and the plugin will load
and begin playing the file! (Note: You will require QuickTime 2.0 or
greater and to get different instruments you will also need to have the
QuickTime Musical Instruments extension installed!)
Terry Greeniaus
10 March 1996
