Netscape 2.02 Make Over
Download: http://archive.info-mac.org/inet/web/nt ... keover.hqx
This is for Netscape Navigator 2.02.
This little guy will change the fuzzy purple icons on your
buttons to cleaner looking ones, give you a new Netscape startup splash
screen, and several other nice little changes. A Patch for the other
versions of Nestscape is also available, if you don't see them around you
can e-mail me and I'll be happy to send you a copy. Virus checked with
Disinfectant and Virex.
Netscape Make-Over may be included on a CD-ROM, provided:
1) It is not modified in any way.
2) This ReadMe file is included in the same folder.
3) I am notified and receive a copy of any CD-ROM on which it appears.
