dump-netscape-cache.hqx
Download: http://archive.info-mac.org/inet/web/nt ... -cache.hqx
This is an AppleScript. It isn't much, but I think it's a worthwhile
one. All this basically does is dumps the Netscape Cache Ÿ file, which
is filled with virtually useless items from Netscape. It takes you from
your hard drive root directory all the way to the Cache Ÿ, then puts it
in the trash and deletes it. I set up the memory to 5,000 Kb‹at the
time my cache file was 2.3 MB‹but if you want to change this to suit
your needs, go into "Get Info" under the "File" menu, and change the
Suggested Size and the Minimum Size.
DEREK B. BATES
Email: [email protected]
Web Addresses:
http://members.aol.com/lionhead/index.html/
http://www.geocities.com/ResearchTriangle/Lab/2851/
