ScreenView CGI 1.0b1
Download: http://archive.info-mac.org/inet/web/cg ... i-10b1.hqx
ScreenView CGI allows you to view your server's screen from any computer
on the Internet. ScreenView CGI comes in two versions, 68k and PPC, and
will run on any Macintosh running System 7.5 or later. Choose the
version appropriate for your Macintosh. QuickTime 2.0 or later is
required, the CGI will still launch but the screenshot will not be taken
if QuickTime is not installed.
Ideas For Use
- Webmasters can use ScreenView CGI to monitor their server activity from
afar.
- Those of you with personal servers can use ScreenView CGI to show
others how your server is set up.
- ScreenView CGI can be used to troubleshoot server problems from a
distance.
- ScreenView CGI can be used to stream screenshots from one machine to
another when called repeatedly.
- ScreenView CGI can be used to maintain daily screenshot logs of server
activity and server load by capturing status screens.
Full instructions in the archive...enjoy!
