PopDriver 2.3
PopDriver 2.3
Download: http://archive.info-mac.org/inet/web/cg ... 23-cgi.hqx
POPDRIVER v2.3 for MACINTOSH comes either as a CGI or as a WebStar Plugin.
It allows you to navigate to other links using popup boxes, lists or
radios with or without a Submit button.
It can also manage frame target.
There are two CGIs, one for PowerPC and one for 68K. The PLUGIN is made
for PowerPC.
Technically, PopDriver redirects calls made by the browser-user when
submitting a selected item from a pop-up menu. Any valid URL can be
returned by Popdriver. You can place any number of popups in a page.
PopDriver is a try-before-you-buy product that ships in evaluation mode.
Use PopDriver in evaluation mode until you are sure that it is right for
you.
REGISTRATION : [email protected]
