CGI-Bolt version 1.0
Download: http://archive.info-mac.org/inet/web/cgi/bolt-cgi.hqx
CGI-Bolt Version 1.0
By Grant Neufeld - [email protected]
http://arpp.carleton.ca/cgi/cgibolt.html
CGI-Bolt is a Macintosh web server add-on which can restrict unauthorized
CGIs from running.
In a nutshell, it enforces UNIX "cgi-bin" style restrictions for Mac web
servers.
It is primarily intended for servers where multiple users have uploading
privileges, but shouldn't be uploading CGIs. CGI-Bolt can restrict a web
server so that only CGIs in the authorized "cgi-bin" folder and its
subfolders will operate.
CGI-Bolt is Shareware.
A license for a single computer is US$25. RAIC, Site and World-Wide
licenses are also available.
You may use CGI-Bolt on a web server for 21 days before you must decide
whether to keep it or pay for it.
Registered users will receive the following via email:
1) A 'FAT' CGI-Bolt CGI
2) A 'FAT' CGI-Bolt WebSTAR plug-in
3) The above will have the option of configuring the name and path of the
cgi-bin folder.
(Fat means it includes native code versions for both PowerPC and 680x0 -
the distributed version only contains 680x0 code.)
http://arpp.carleton.ca/grant/
