Download: http://archive.info-mac.org/inet/web/webcon-222-jp.hqx
This is the Japanese version of the Web Confidential for Mac OS package.
Web Confidential is an intuitive, easy-to-use program for
managing user IDs, passwords, registration numbers, and the like.
While Web Confidential is suitable for a wide variety of personal data,
from credit card numbers to serial numbers, Alco Blom designed Web
Confidential particularly for the World Wide Web in mind. "Increasing
numbers of Web sites maintain some form of user registration," points
out Blom. "You may not realize it, but in the course of time you may
registered at a couple of dozen sites. Do you remember the passwords
you entered for all of them?"
Web Confidential allows Web surfers to store URLs, user IDs, and
passwords in one secure location. Web Confidential can automate the
process of logging into a password-secured Web page by automatically
passing URL, user ID, and password to your Web browser.
For opening pages containing personal account information at commercial
sites, Web Confidential allows you to automatically fill in WWW Forms
with user ID and password fields.
To ensure the personal information stored in Web Confidential remains
confidential, the program's password files can be encrypted using
state-of-the-art encryption technology.
Changes in version 2.2.2
Included is a new version of the Conduit which fixes the occurrence of
duplicate records, which would appear when synching your handheld with
two different Macs.
These items are new in the application:
*Shortcut Command-Backspace for the Delete Card command.
*Added an 'Encrypt' command to the File menu.
*Minor bug fixes.
*Web Confidential files are now binary-cross platform with the Windows
application.
*Import command. You can import tab delimited text files.
*A new preference to show the passwords as text instead of bullets.
*The Conduit for use with the Palm application has been rewritten to
accomodate the new file format.
