Web Works 2.0
Web Works 2.0
Download: http://archive.info-mac.org/inet/web/web-works-20.hqx
Web Works 2.0 is now available for downloading. A new feature like support
for more then one browser to accomplish a certain task, all in one
application is a great addition. The rewritten code makes Web Works 2.0 twice
as fast as previous versions for certain features. The cache, and security
features are pre-configured to tailor to your browser(s). Netscape, Internet
Explorer, and America Online browsers are supported.
Here's an example: If you have all three browsers mentioned above, and
you want to clear all their caches at fast, you can select "Cache" in
the Web Works application and have it delete all their caches at once.
The same goes for the security feature. The best part about Web Works
2.0 is the price--$5.00 for a registered version!
The Mouth Blazt Software site is at:
-David DeParolesa
