WabbitPwo - Shareware URL Manager
Download: http://archive.info-mac.org/inet/web/wabbit-pwo.hqx
WabbitPwo is the second generation in the Wabbit family. Most of the
original concepts of WabbitDA are implemented in WabbitPwo, but the program
has been further enhanced to simplify managing your bookmarks.
WabbitPwo makes navigation and housekeeping easy by using an already
familiar "Finder" format to store each of the unique address types
available on the internet. You can create specific items/topic folders for
URLs that reference a topic. And since WabbitPwo mimics the Finder you can
expect to already know how much of it works.
Any of your data stored in WabbitPwo is available from ANY application,
even if you are not immediately connected to the Internet.
WabbitPwo is mostly stand alone, but he is primarily designed to work in
conjunction with Internet Config. By installing Internet Config, you can
simply CMD click any URL entry in WabbitPwo's database and he will either
launch the selected helper application or if it's already running, bring it
to the front and pass it the URL. Navigation made simple!
Internet Config aware (advised for full functionality)
Drag and Drop savvy
OS8 Compatible (System 7 or newer)
Time online sessions
Simple interface operation
Of course WabbitPwo is not your garden variety book marker....
WabbitPwo is shareware ($10) and may be included on any CDROMs.
Demo version is limited to 250 URL's. Registering your version removes this
limitation.
http://www.intergate.bc.ca/business/mel/
mailto:[email protected] OR [email protected]
