Summary 1.0.2
Summary 1.0.2
Download: http://archive.info-mac.org/inet/web/summary-102.hqx
Summary 1.0.2 - The log analyzer that tells you more!
Summary is a web server log analysis program. With over sixty
reports, you can find out more about your visitors, connection
bandwidth, referrers, and all aspects of your website, than
with any other tool.
Many unique reports including: search words used to find your site
in major search engines, periods when the server was down, most
commonly used entry points into your site, visitors connection
(modem) speed.
Summary 1.0.2 - Fixed a parsing problems in WebSTAR logs with
agent string as first field. Now treats "::index.html" and
"//index.html" the same as ":index.html" or "/index.html".
Summary 1.0.1 - Fixed a crash caused by requests ending in "/.".
For more information and the latest updates check:
http://summary.net/summary/
