Download: http://archive.info-mac.org/inet/web/ri ... or-111.hqx
Program Name: Ringsys WebMonitor
Version: 1.1.1
Resource url: http://www.websitewatchers.co.uk/produc ... 1_1_x.html
Description: Do you know if your web site is running properly? WebMonitor does!
WebMonitor will check your site every few minutes. I will alert you immediately if
if your site doesn't work properly. With the web front end, setting up the web monitor
has never been easier. Also, thanks to the alert escalation, you won't miss another important
event on your site: someone else in your team will pick it up and do something about it.
MacOS
http://www.ringsys.co.uk/webmonitor/try ... 11inst.bin
(Inludes JVM: 8.8mb)
(Requires JVM 1.1.6+: 1.6mb)
Screenshot:
http://www.websitewatchers.com/wm11_screenshot.gif
