Download: http://archive.info-mac.org/inet/web/mtm-ppc.hqx
This is the PPC installer for Meta Tag Manager version 1.0.3 from YAV
Interactive Media (http://www.yav.com), the first and only software of its
kind for the Macintosh. Meta Tag Manager ($30) is the ultimate tool for
fine-tuning and optimizing a document's meta tags. This process can enhance
a page's search engine relevancy ranking and assure that queries that
should find a particular page, do in fact find that page. Anyone creating
webpages should be using Meta Tag Manager.
Meta tags are usually not visible in a browser but are used by search
engine "spiders" to index and rank a website or homepage. Every search
engine has its own approach to handling on-line documents and even their
utilization of meta tags varies widely. Rather than leave the fate of a
meticulously crafted web presence to a spider's often overly generalized
methods, Meta Tag Manager lets the individual take control. By providing
dozens of options to automate the management of meta tags, Meta Tag Manager
makes it easy to analyze and maximize the important meta tags of an entire
website or a single html document.
Meta Tag Manager provides ongoing feedback about how a document's meta tags
will be treated by up to ten search engines (including the top seven). Meta
Tag Manager generates custom advice in easy-to-understand English. One
click of the "Update" button can add ten meta tags auto-formatted in
optimum syntax to a document. And Meta Tag Manager can conditionally add,
append, prepend, or merge tags to a whole group of files with a single
press of the "Batch" button. Collect all keywords from a website. Analyze
the interaction between keywords, headings, and body text. Designate often
used material to be added automatically to important tags. "Carry over"
tags from one file to another. Strip unwanted meta tags. Create "Tag
Reports" and much more.
This file may be included on the commercially available CD-ROM of the archives.
