DOS Mounter 98 demo v2.0.1
Download: http://archive.info-mac.org/app/dos-mounter-98-demo.hqx
DOS Mounter 98 now includes 148 new extension mappings including mappings for
Word98, Excel98 and PowerPoint98. It mounts floppies, removables, and hard
drives up to 9GB and seamlessly access DOS and Windows directories and files
from DOS disks. Unlike any other file interchange utility, DOS Mounter98
provides bi-directional transfer capabilities so files returned to the PC
retain their Windows95 long filenames and extended Mac filenames are
automatically truncated to standard 31 characters.
The full version includes a formatter capable of formatting in HFS, HFS+, and
DOS. You can even create multiple partitions of Mac and DOS on the same disk.
The full version is available from Software Architects, Inc. at
www.softarch.com.
This demo is good for 21 days. Its only functional piece is a control panel.
Trash it when the trial period is over. Removable media drives must use DOS
Mounter's driver. Temporarily disable other driver extensions (i.e. Iomega
Driver).
