Analog Helper 1.2.2 - Log analysis assistant
Download: http://archive.info-mac.org/inet/web/an ... er-122.hqx
Analog Helper is a graphical configuration tool for the Mac OS for
Analog, which is a free program to analyze the logfiles from your web
server. Analog Helper lets you control and preview the results of
hundreds of settings, and means you need not touch the complex syntax of
Analog's configuration files.
Analog Helper can also configure Report Magic for more advanced HTML
reporting, automatically configuring Analog to output data for Report
Magic, writing Report Magic's config file and running Report Magic.
However, you need not be aware of any of this process; simply set up your
analysis as required in Analog Helper, and it will do the rest of the
work.
Version 1.2.x adds full support for the new reports in Analog 4 and full
integration of Report Magic for advanced HTML reporting.
