Eudora Pro -> MacPGP Scripts v1.0
Post by Info-Mac » August 24th, 1995, 9:00 am
Download: http://archive.info-mac.org/inet/mail/e ... -10-as.hqx
These scripts are modified versions of those enclosed in the MacPGP 2.6.2
package.
They also include small snippets and inspiration via Robert's PGP scripts.
They are much improved in my opinion because:
1) They are more consistent in syntax and easier to read.
2) They don't do strange things like save decrypted text as a script property?!?
3) They don't require scripting additions (although it helps).
4) And finally they are compatible with Eudora Pro v2.1.3, or more
precisely they avoid a gigantic bug in this particular version.
The best way to run these scripts is with OSA Menu 1.0.2 or higher and the
scripting additions they like to have handy are Jon's Commands 1.3.6 or
higher and Menu Events 1.1.2 or higher.
To avoid the bug in Eudora Pro v2.1.3 I had to work on the message in
question while the window for it was closed. This is not easy because you
can always address the top open window as message 0 but once it's closed
you need a more specific reference. Therefore before encryption the
selected message is closed and moved to the end of the Out mailbox (or
copied to it if it was not already in the Out mailbox). Also before
decryption the message is moved to the end of the In mailbox (even if it
was already somewhere else). I don't imagine that this is too much of a
problem considering that most of the time moving will consist of putting
the message right back where it was. But, if anyone has a better idea I'd
gladly listen...
You can open these scripts in Script Editor and modify them to your
heart's content (and I encourage that you do) as they still fall under the
GNU General Public License of the original scripts.
I don't really intend to maintain these scripts, I just thought I'd put
them out in order to save some people the trouble I went throught to make
them.
