Eudora 3.0 Pro Filter Sounds
Download: http://archive.info-mac.org/inet/mail/e ... nds-10.hqx
Here is a Eudora plug-in with filter sounds generated with the PlainTalk
software. You can have these sounds played by the filtering mechanism of
Eudora 3.0 Pro, which will give you an audio alert for messages that match
criteria that you define. To use these sounds, place the plug-in in the
"Eudora Stuff" folder in your Eudora folder, and define filters to play
these sounds.
These sounds are freeware, you may copy or modify these sounds in any way
you like.
A request: if anyone knows a method of redirecting PlainTalk-generated
sound to a sound file (System 7 sound or AIFF or ...) directly, without
recording and playback using an external recording device, I would like to
know.
The archive contains the following sounds:
- You received a message with an attachment
- You received personal mail
- You received an upgrade notice
- You received a forwarded message
- You received a redirected message
- You received a message that requires confirmation
- You received a message from a VIP
- You received an urgent message
- You received a very urgent message
- You received a message that requires your attention
- You received an important message
- You received an encrypted message
- A message was put in the trash
- A message was answered automatically
- A message was forwarded
- A message was redirected
