Email Checker 2.5.5
Email Checker 2.5.5
Download: http://archive.info-mac.org/inet/mail/email-checker.hqx
Tuesday, May 19, 1998
Carnation Software releases Email Checker 2.5.5
with support for Bare Bones Software's Mailsmith email program.
Email Checker checks your email at specified time intervals using your
email program, AppleScript and OpenTransport/PPP. Email programs
supported
are: Claris Emailer and Claris Emailer Lite, Eudora, Eudora Pro or Eudora
Light, Mailsmith and Outlook Express.
Email Checker will keep a running total of the hours you spend online and
automatically reset the hours to zero each month at the beginning of your
billing cycle.
It will even work if another application makes the PPP connection for you
(as long as Email Checker is running).
Works with System 7 as well as OS 8.
Flexible options let you check mail at a specified time interval in
different ways:
1. Connect to the Internet, get mail and then hang up.
2. Connect to the Internet, get mail and don't hang up.
3. Get mail only when already connected to the Internet.
4. Get mail when your Mac starts up and continue checking for mail
throughout the day.
If you choose to automatically connect when checking for mail, PPP will
dial and connect in the background so you can continue working. Easy to
set up. Uses your existing email accounts from your email program. Status
window has a progress bar showing how much time is left until mail is
checked again. Also shows the PPP connection status (open or closed),
baud rate, minutes connected and accumulated hours online.
Email checker is available from the Carnation Software web site at:
$25.00 Shareware
Rich Love - Carnation Software, Inc.
Terminal emulation for Macintosh.
Email Checker
Desktop Pictures for OS 8
http://www.carnation-software.com
