XTND Update
XTND Update
Download: http://archive.info-mac.org/inet/html/x ... update.hqx
Update to: * WMF / BMP XTND Translator V1.01 - Fix BMP RLE and better filtering
of BMP files * QT Graphics Importer XTND v1.01 - Fix importing of JPEG's.
Update to: Mark's TranslatorPackageXTND V2.0.sit
Other updates can be downloaded at:
Bug fix details: >I'd like to import or at least link jpg files within FileMaker
Pro 3v4. >You have a XTND Set to do this job. But it doesn't work with me. Though
>I have QT 2.5 and the filter QT Graphics Importer appears in the >filterlist I
keep getting the msg the translater cannot read the file >(ordinary jpg file).
>What am I doing wrong?
Importing test using V1.0 of the QT Graphics Importer XTND with sample GIF and
JPEG files into FileMaker Pro V1.0v2, ClarisWorks v 4.0, MacWrite II work with no
problems.
The same files give the same results as you are reporting using FileMaker v3.0 (I
have lots of memory free in filemaker and system heap - so it's not memory).
PhotoShop, PICT, and JPEG importing now works with the new update to v1.01, but
GIF still doesn't work.
